I have captured music videos from my sat in MainConcept in MPEG2 720x480 and I would like to cut them into individual videos. Can anyone recomend a good program to do this.
I use Womble's MPEG-VCR to edit commercials out of TV programs and it works great. No recoding and it makes perfect cuts. Also fairly fast compared to Moviefactory-3.
I used Womble MPEG-VCR to split the videos up, and it did a great job. I then used TMPGENC DVD Author to author my videos into a DVD. My MPEG2 files were captured @ 720x480 and the audio was PCM. In TMPGENC I chose the same settings. Then after it created the DVD files I let it burn it to a DVD-RW @ 2X speed. When I played it in my Panasonic RP-82 it was really jumpy. The vob files on my hard drive play ok, so i'm guessing this jumping was due to the burning process?
I have previously downloaded videos (in vcd format) and used Ulead DVD Workshop 2 and it turned out fine.
Any help is appreciated.
Thanks -
I've been using Womble and I just noticed that it re-encodes my audio to MPEG audio, which I capture in PCM. Is there any way to cut my files and keep my PCM audio?
Edit/cut MPEG2 TS
By jon222 in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2014, 15:30 -
What program can I use to cut segments from a mp4 video?
By alc112 in forum EditingReplies: 9Last Post: 1st Jul 2011, 18:31 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 00:52 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 15:55 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12
