ok..i got sizzle to work once! but now it crashes every time. i've repaired my disk, my permissions, etc.
what could be the problem? i'm trying to burn a 3.09gb dvd.. and it crashes. i have plenty of room on the disk(hd) too.
problem 2, which isnt video related but ties into the sizzle problems.....
i decided to try to use sizzle under 10.2, and to do this i had to install 10.2 on a external hd. but for some reason, the disk wont start up. all i get is the grey apple. ????
any suggestions for these problems?
thanks
alot!
What Mac are you using? If it is a model that shipped with 10.3 it probably won't boot in 10.2. If you hold down the option key at startup does this other drive show up as one of the startup options?Originally Posted by gr8fl4295
i have an older g4 powerbook (800mhz).
i'm trying to install on an external firewire drive.
i've got 2 external FW drives, one with 10.3 and one with 10.2 (now).
i hold the option key down and yes i can see the drives as bootable drives. but when i select the drive that has 10.2, it acts like it wants to start up, giving me a light grey screen and a dark grey apple, but sits there with no twrilly progress thingy.
couple avi with problems
By spiritgumm in forum Video ConversionReplies: 2Last Post: 12th Jun 2010, 18:34 -
Couple of problems with my EX1.... help?
By lukeflegg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Feb 2010, 13:35 -
DVD2Mpg Couple of problems
By Lucky_Bagota in forum DVD RippingReplies: 1Last Post: 21st Mar 2009, 16:21 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
