Anyone able to recommend a newbie a good MPEG to AVI conversion program/tool? I tried VirtualDub-MPEG2 v1.5.10 after it came up on doing a search at this site for such a comnversion. I followed the guide entirely using DivX v5 codec (as recommended) and the end product wasn't that great, I had lost a fair bit of picture quality, it went grainy.
Anyone recommend a high quality program which can minimize the loss of picture quality?
The loss of quality is due to the settings of the codec you use, not the encoderprogram (vdubmpeg2). Try to raise the bitrate or lower the resolution. Make sure you use at least 2 passes.
When you say MPEG -> AVI do you really mean DVD -> DivX (it sounds like it). If so you might want to check out Gordian Knot (http://www.doom9.org). It's a collection of programs with a frontend program to will set everything up for you, then you just hit go, and come back when it's done. Great program, lots of guides here and at doom9.org
Hey thanks for the help!
I just tried Dr DivX and the conversion was great, much better than what I got with VDub, the program seemed far more user friendly as well (I'm really quite new to this sort of thing). It does do two passes as well.
I'll try the Gordian Knot program next and see how I get on with that.
The files I am converting were created by my capture card, I capture in "Extra Long Play DVD" mode which produces an MPEG files.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
