  1. How should i cut unwanted material/scenes, within DVDLab ?
    I tried it but it gets very confusing, it's easier done in TMPGEnc DVD Author, but it has less features i need, couldn't find a guide for this
    "doing it" with DVDLab.
    DVDLab has become my favourite dvd author prog. but the edit function
    is a bit un-handy for me, does somebody has any experience with this,
    using DVDLab ?
    Thanks,
    Yodel
  2. DVDlab is not an editing tool. It is an authoring tool.
    Suggest videoredo or some other mpeg2 editing tool.
    There is a reason why God gave us one mouth and two ears!!!
  3. Originally Posted by awlchu
    You CAN edit encoded material within DVDLab, TMPGEnc DVD Author,
    Within DVDLab, it can, though not easy, that's why i am asking...
    there are lots of easy progs. for editing, but i just want to use as less
    progs. as i need to, in just few steps: capture > encode > author.
    Thanks,
    Yodel
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    to bypass a scene .. just put a chapter at begining and end of scene and link the first to the second ..
    well its real quick method for already encoded material ..
  5. Originally Posted by BJ_M
    That's also a idea.. will look into this with my next project, how to
    do this, thanks.
    Thanks,
    Yodel
