Hello All
I am trying to split my home captured dv-avi file into sound and vision. I am using TMPGenc to encode the movie and ffmpeggui to create an AC3 dfile from the audio.
When I select the source in ffmpegguiI get a red cross error stating "Floating Point Division By Zero" on the screen. However I then continue and it appears to create the AC3 file OK. Anyone have any ideas why thismessage is occurring and what it means?
Cheers
----Figured it out yet?
----What's that?
----Who's the best pilot!
TOP GUN (1986) -
It can't get the correct time in the source file, it doesn't effect the encoding. I maybe will fix it in next version...if I make a next version.
Thanks very much Baldrick, I did not think it effected the output, I used it on a compiled DVD and it was fine.
Did not realise it was your code, so thanks once again!----Figured it out yet?
----What's that?
TOP GUN (1986)
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47 -
Photo enlargement & division for printing
By kippard in forum ComputerReplies: 7Last Post: 17th Sep 2007, 02:35
