Okay,
I am a newbie here but have been around other places for awhile. I used dvflash and the 2.50 firmware that I downloaded from one of the pages found here.
My DD0203 said tray out, looked like it was flashing and then just hung up for 10 minutes or so. I rebooted (mistake #1), then couldn't get into Windows until I disconnected the power to the DD0203 (maybe mistake #2).
Rehooked power, reset BIOS to boot from Arive (also had DosFlash and lastest bin on floppy) but it won't recognize the drive at all.
Is this deader than a doorknob or can I get it going again.
I also have an LG DVD-ROM, Intel 3.0ghz, 1gb DDR3200, Interl Mobo if that helps. I am also considering dumping the Optorite and getting either a LiteOn or Pioneer. Opinion there?
Thanks,
Pete -
Check out this thread:
http://club.cdfreaks.com/archive/topic/81136.html
At the very bottom is:
Posted by: yanon
OPTORITE DD0203 (aka SANYO CRD-BPDV2)
Optotrite's window firmware flashing utility is prone to failure. You will cause the firmware flashing utility to crash if you accidently press the "ok" button twice. If the firmware flashing utility crashed while it's updating the firmware, then the optorite drive will appear to be dead (no LED light, no motor spinning noises) even during a reboot. Using the well publicized mtkflash recovery technique will not let you re-flash the optorite drive.
After spending an hour fiddling with boot menu and mode selction pins, i figured out how to make the optorite DD0203 work again. Here is how I did the recovery, 1) copied dvflash.exe and the firmware bin file onto a dos bootdisk 2) move the factory-use-only pin from the right most position to the 2nd right most position. 3) make sure the ide mode selection pin is not on cable select. 4)reboot your computer with the bootdisk 5)start the dvflash utility by typing "dvflash ***.bin". (*** denotes the firmware filename)
6) follow the onscreen instruction (dvflash will automatically detect which channel your optorite drive is on) 7)move the factory-use-only pin back to the original position 8) reboot your computer once the recovery is completed.
I think the recovery can be done regardless of the IDE channel and master or slave position your optorite drive is occupying. The aforementioned instruction should also work for the MSI 4X DVD Writer and Sanyo DVD Writer since they all use the same chipset.
However, you may want to try re-flashing the msi or the sanyo drives without moving the factory-use-only pin before using my method.
Bin Laden killed!!!
By deadrats in forum Off topicReplies: 1Last Post: 2nd May 2011, 12:03 -
HELP! I killed my PHILIPS DVP5996K/98!
By videoname in forum DVD & Blu-ray PlayersReplies: 9Last Post: 8th Jan 2010, 00:43 -
This killed me!!!!! Everyone need's one of these!!! LOL!!!
By Noahtuck in forum Off topicReplies: 6Last Post: 7th Aug 2009, 22:18 -
Killed my DVD recorder
By Kschossi in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Mar 2008, 23:57 -
Australia's Crocodile hunter killed
By MeDiCo_BrUjO in forum Off topicReplies: 42Last Post: 4th Sep 2007, 14:50
