Got a new PC recently with a new DVD Burner, the problem I used to have is still happening. (SCSI Error)
So now, I am pretty sure it is the disc's that are doing this, I just wanna make sure you think it is too.
If it is, I will get some dearer ones.
Thanks,
Liam.
You need to give a better description of your error - and what you are doing. What you have said makes no sense at all.
Does your burner burn a CD okay?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
it sounds like you might have a problem with your aspi layer, try forceaspi
Quantum DLT8000 & SCSI card Available
By sdsumike619 in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Dec 2011, 17:07 -
SAS SCSI Drives problem?
By videobread in forum ComputerReplies: 5Last Post: 18th Nov 2011, 10:17 -
What is the best use for a 10K rpm scsi hard drive?
By Haopengyou in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2010, 10:00 -
SCSI RAID Mirror to 2 locations
By Ozzyjim in forum ComputerReplies: 5Last Post: 23rd Mar 2010, 21:57 -
HP DVD Writer 300n SCSI CdRom Device Driver Issue
By link2009 in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2008, 17:50
