When I go to source range, what is the max frames to fit on one CD?
Different Subject
I installed the VFAPI plug-in and I think I screwed up the settings in "Environmental Settings-->VFAPI Plug-in". What is it suppose to be? Ever since I changed it, and I watch it while it is being encoded, the screen is much more square like. What's the problem? -
Can someone just tell me what there settings are? For: TMPGEnc > Environmental Settings... > VFAPI Plug-in
Please tell me what each of your prioritys are. I would be glad if you told me if yours is working perfectly/great.
Thanks -
If TMPGEnc is able to read your input videos, your VFAPI plug-ins are probably working correctly. Your issue is most likely being caused by a change you made to the aspect ratio or resolution. The Size and Aspect ratio ratio options on the Video tab and the Source aspect ratio and Video arrange method on the Advanced tab need to be configured properly for your video.
-Cart
http://www.geocities.com/lukesvideo/index.html
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
