Results 1 to 9 of 9
  1. Hello everyone.
    I'm trying to backup my coldplay and Simply red dvd. I have tried it with dvd shrink, dvd decrypter but it doesn't work. When I backed them up to my computer and I try to play them, the movie is stuttering.
    Does anyone know how to handle this problem.
    Cbri
  2. What errors do you get with DVDDecrypter/DVDShrink?
  3. Dvd shrink and dvd decrypter are doing there work allright and I also have dvd43 tray running. But when the Dvd is on the computer and you're playing one of the files, it's stuttering, by all the files. This isn't a fault because of the wrong region code, but what fault this is I don't know.
    Greetz Cbri
  4. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    are the discs scratched at all?
  5. Have you tried it on your DVD player?
    Have you tried other brands of media?
    Do you use labels?If so DON'T.
  6. I don't do anything wrong I am almost sure. I have read a lot of things about copying problems on this forum, but I couldn't find any solution.
    I'm quite sure that this is a copy protection, does anyone know how to crack this protection?
    Greetz Cbri
  7. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    It isn't copy protection, but are you sure it isn't Mick Hucknalls voice that's stuttering, he sure is a shite singer
    You need to try the disks in other computers, standalone DVD drives.
    What is your system spec, are ou running other programs when playing the DVD, what software are you playing the DVD's with?
    Will Hay
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  8. Hello here an update about my backing up problems.
    I have a little succes with backing up coldplay. The files on my computer are almost fine. But two songs are still stuttering. Does anyone know who to solve this problem?
    Greetz Cbri
    Nov 2003
    I DON'T KNOW
    Tell us what dvd software your using.
    Windows Media Player dose not play dvd.
    You to try it on stand alone dvd player.
