I have used lots of different brands/manufactures of -/+ R/RW and I have had my fair share of coasters for many different reasons ranging from sheer carelessness on my part to defective media. My question is this: Suppose I have a pristine copy on a TY and through some act of GOD (or some other devine entity) I have a pristine copy on a CMC. Down the road if they are both cared for properly and in the same fashion, will the CMC be more likely to give me problems - or - do all problems relating to lower quality media revolve around getting a decent burn? (as opposed to keeping a decent burn (i.e., scratches more easily, causes more read errors a few years from now, etc.)) Consider as an example a burn of 4gigs so we don't have to deal with edge of disc dye issues.
No, I'm from Iowa. I only work in outer space.
So far, no, nothing has been proven. Once it is burned, and confirmed good (by watching whole thing AND good disc check on PC), considering it has good care, should last decades.
I will second that. Nothing is proven until now, so if they work good for you after a burn and no errors, there is no proof that your TY will last longer than your CMC. None what so ever.
If you do some reading through this forum, you will find instances of people that used cheap media which is now not readable.
Those tests are inconclusive because the media was never thoroughly checked to begin with. I've found that in 100% of the cases I've reviewed on the matter.Originally Posted by VinnySemWant my help? Ask here! (not via PM!)
Burn subtitle and change font size
By Nazarenojr in forum ffmpegX general discussionReplies: 8Last Post: 14th Mar 2011, 04:25 -
How to change this script to burn idx/sub subtitles?
By MousE0910 in forum SubtitleReplies: 4Last Post: 21st Feb 2010, 13:04 -
WMV to DVD without any change in quality?
By Mudchild in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2009, 02:37 -
Can't change book type with Img Burn and Samsung 203N
By Vidikron in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Apr 2008, 02:41 -
Cannot change burn speed with DVD data projects
By mekuka_pinasem in forum DVD & Blu-ray WritersReplies: 14Last Post: 20th Aug 2007, 20:43
