i used dvd decrypter to rip the entire The Matrix dvd into ISO mode.
then i used daemon tools to mount the 7GB ISO onto drive G: (virtual drive).
next, i used dvd copy to transcode. the source was drive G:, the destination was my desktop.
as it transcodes, i see a MOVIE folder, then VIDEO_TS folder inside it, then the normal dvd files inside VIDEO_TS. (IFO,BUP,VOB,etc).
then when dvd copy finishes transcoding, everything inside the VIDEO_TS folder is DELETED, EMPTY!!
ive done this 3 times, why does dvd copy delete everything inside the video_ts folder?
thanks
Hope this helps, found it at doom9.
dvd copy
After transcoding your dvd to HD intervideo dvd copy is going to parse the files (takes about 4 minutes)in those 4 minutes you select all files and make them read only. when dvdcopy is done the files are not gone.
Intervideo does not want you to save the decrypted files to your harddrive. I believe it has to do with legality issues. -
Intervideo's dvd copy express (the new barebones version sold at Sam's club) does NOT delete the original VIDEO_TS contents.
I think it is wrong for any software to modify the source data without your permission.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!!
Vegas 10 Platinum Problem
By REDRUMxINxTX in forum EditingReplies: 6Last Post: 26th Jan 2012, 19:53 -
SONY Movie Studio Platinum 10 rendering problem!
By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 18:52 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 01:30 -
Getting audio desync problem when ripping with DVDFab Platinum 4
By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 14:50 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 21:12
