I know have cracked how to get the ATI AIW Pro 32Mb to work in VirtualDub using the latest drivers from the CD, I just now need some advice for some top capture settings in VirtualDub then to encode to VCD or SVCD. At the moment I'm limited on Disk space because my second 10GB hard-drive has busted. But my dad is hopefully going to get me a 7,200rpm 40GB hard-drive after the weekend. Here are my Computer Specs for you to work around.
Windows ME
500 MHZ Intel Celeron w/ 160mb RAM
ATI AIW Pro 32Mb
10GB Hard-drive (not sure wat speed) (Split into x2 5GB)
(Hopefully) 40GB Seagate 7,200rpm EIDE Hard-disk
Hercules Gamesurround Fortissimo II sound-card
I'm not needed to worry about Macrovision, I've had them problems in Video-on-Demand capturing for live MPEG1/2 capturing. But I've found a crack to disable the driver to set off the macrovison protection for TV-In (not TV-Out).
What drivers are you using? I too am trying to use Virtual Dub with my ATI All in Wonder, but it won't recgonize my device drivers.
Raiderray -
its very confusing but i'll try and tell u. Right, u need to tell me what Windows version are you running??
95, 98, 2000, ME or XP?? -
I'm also curious as to how you've managed this ... oh, and my operating system is Win98SE.
whats virtual dub?
»®»ŦħĄňķŜ«®«
»®»Life Is Góód«®«
»®»Its All Gööd«®« -
I have ME.
I get good capture quality at 480 X 480 with AIW capture program, but can't capture any higher (either AVI or MPEG2) w/o MAJOR dropped frames!
Raiderray
<font size=-1>[ This Message was edited by: raiderray on 2001-10-25 16:01:06 ]</font> -
Read this post:
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=60704&forum=2
I was having the exact same program, downgraded my drivers and now VirtualDub works perfectly! BTW if you're using ATI AIW and don't have VirtualDub set up, DO IT! My captures are SOOOO much better going AVI to MPG than compared to directly to MPG. -
mikewg,
I checked the link you gave, but I found that downgrading to MMC6.3 (I currently have 7) won't work with the AIW Radeon that I have.
What ATI do you have?
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 09:13
