after trying for a year or so i managed to get my dazzle usb to transfer some hi 8 video onto movie star....now as i'm an absolute beginer my problems have started over again.....
when i drag and drop the clip i've already captured.....the clip appears upside down in the editing window.....eh? then what am i supposed to do to trim it down....this is a major headache
i want to add text to the start of the project and then edit varoius clips to make a hour or so of stuff.....
please can anyone help?
What Dazzle unit? Regardless of which one, you need to ditch moviestar. If its a DVC 150, you have two choices to get any use out of it.
Either "upgrade" to the new Pinnacle drivers and software, or use the dvxcel test utility you should already have. It is only used for capture, though, so you would dump the output from it in another mpeg friendly editor. Ulead VS7 works well and so does the new Pinnacle studio. -
erm....thats a bit complex for me to understand......all i know is the dazzle is a usb .....i need this as all my vids are on camcorder tape at the mo..........as for the editing software i havn't a clue.....it's moviestar 5 or something......it's installed on my girlfriends pc
as i say i would like to adit all my clips into a movie length thing with titles
thanks c -
I don't understand the whole "erm" thing. Is it basically the same thing as "um" in the US, or does it actually mean something?
Anyway, Moviestar is notoriously bad. I would not even attempt to use it. Find out what dazzle unit you have. I have the DVC 150 so I'm not sure if what I tell you will be accurate for another unit. you should also post all of your computer specs in your profile. it will be hard to help if I can't tell what you're using.
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 10:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 01:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23 -
Using 500GB usb drive as player on Standalone with USB
By OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 05:36
