How true is this article?
http://www.dvdplusrw.org/Article.asp?mid=0&sid=3&aid=11
From my limited memory of discussions I've read, most of the points listed also apply to DVD-R/RW. Is this correct? I've been trying to read up on DVD recorders.
And was not DVD+ first developed as a Data standard and then got on the video bandwagon when the customer demand when up?
Also, "DVD+R/+RW recordings are always DVD-Video compatible". Not sure if they mean they meet the DVD specs or that the disks are always compataible with DVD players? I know the latter is not true...
Any comments?
Results 1 to 9 of 9
I will oblige..........
Sorry Phil but your continuing denial of being a Pioneer/-RW fanboy cuts little ice with most on this forum .
The DVDplusRw set top forum is like a morgue these days-so few people complaining about anything-it seems very few are having problems with Philips set tops now.
On the subject of Pioneer -do you know if the Pioneer DVD-RW recorders will be able to use the 4x -Rw media that they have shot themselves in the foot with?
http://news.com.com/2100-1041_3-5174034.html?tag=nefd_top
If not it means that retailers have to keep a supply of 2x -RW media to keep all those with older PC drives and set tops happy.
KDH -
listen to philipl, he speaks the truth. nuf said
kdh, GET OVER IT!!!!!!!!!!!!!!!!!!!!! -
And here we go! The Johnsons are out... the tape measures are out... the cries of "MINE IS BIGGER THAN YOURS!!!" are filling the air...
Don't sweat the petty things, just pet the sweaty things. -
Having used many players, settled to owning a DVD+RW recorder, trust that no editing should be done on one. If you edit, get a hard drive version burner, or just use a PC.
I use the recorder as a digital VCR, a capture card for perfect sources, then rip in IFO mode on PC and then edit.
Editing on a DVD+RW drive can easily, and often, corrupt the IFO files.
The DVD+RW has other things going for it though, why I picked it over -RAM/-R recorders. I'll elaborate more on my site when I find time.Want my help? Ask here! (not via PM!)
I too like the features of both + and - set top recorders. I just happen to own a Philips. Never had a problem with it. I would never buy a Philips DVDR70....I'm not blind....I've seen some horror postings about those.
I still do NOT believe it is because of the + format that people are having troubles with some of the Philips recorders. I have had no compatibility issues with my 985 created discs NOR have I had any un-readable discs from my "985 to PC" projects.
I use both + and - discs in my PC and see NO difference in any aspect of the end result. I have never had a compatibility complaint from any of my customers. I sell ONE DVD....it originally came from a Philips Recorder. I send out + and - versions of that recording to customers(after PC editing) and have yet to have someone e-mail me saying that it will not play on their DVD player.
I suspect it would be the same if I used a Panasonic or other -R Recorder for the original recording. -
I was not intedning for this to get into a version war. I just wanted to know if the items in that article were correct or not.
Is there a non-biased site that lists point by point the pros and cons of each fromat (and their recorders)?
Cheers
Is it true we can rip the WHOLE dvd to mkv?
By reapur in forum DVD RippingReplies: 4Last Post: 24th May 2010, 18:43 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 11:27 -
1080p true hd to 720p true hd possible ?
By miss in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 21:48 -
PC World Article:
By wtsinnc in forum DVD RippingReplies: 4Last Post: 19th Jan 2008, 07:28 -
Spintronics article
By ahhaa in forum ComputerReplies: 1Last Post: 8th Aug 2007, 10:05
