Is there much difference in visual quality between dvd and 1/2dvd for shows captured off tv?
I found a huge difference between vcd 352x288 and svcd 480x576 when they were recorded from the same source (a video cassette). Isn't it a reduction is quality to go from 480x576 (svcd) to 352x576 (1/2 dvd).
What is the minimum bitrate people use for making a 1/2 dvd using vbr? I have played around with as low as 2000 with acceptable results but I am after a rule of thumb i.e SVCD shouldn't be lower than 1600 etc.
Cheers
I haven't noticed any difference in going to half D1 for TV recordings, but I tend to keep the bit-rate above 3000.
Hi8/VHS to DVD: which bitrate do you recommend?
Should help you out....Regards,
Rob -
If your source is a tv show recorded on a VHS casette then 352x576 is enough. But (in my opinion) if it is recorded directly from a live broadcast I get better quality at 704x576 DVD resolution and a bitrate around 6000 kbit/s. But it depends on your source. Some digital DVB channels are sent with resolution 352x576 and in that case there is no need to encode higher. If your TV is old and blurry maybe you can't see any difference anyway. In the end you are the only one to judge what looks good for you, so I suggest you do some tests and make tour own conclusions.
If you aim for bitrates as low as 2000 kbit/s I would not use higer than half D1 resolution. For clean sources like DVD or digitally recorded DVB and encoded as progressive I think 2000 kbit/s is fine, especially if letterboxed. But interlaced full screen video may require minimum 3000 kbit/s average bitrate if encoded with VBR at half D1. But this are my opinions so you better test it yourself.Ronny
Converting DV 720x576 with AR 16:9 to AVC using libx264 and FFCoder
By klode in forum Video ConversionReplies: 3Last Post: 11th Dec 2011, 10:57 -
blu ray player says video larger than 720x576
By PSS2 in forum Authoring (Blu-ray)Replies: 4Last Post: 4th Jul 2010, 16:07 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 12:56 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
