hi. does somebody know where I could get the newest drivers for the card? Its been a time since I last used the card, so I'm not uptodate with the drivers, but I cant find drivers for it on the web.
thx
Is this the same as Studio PCTV? If so, I think the Pinnacle support is not so good. If I'm not mistaken it is based on Brooktree 848/878 chipset and so you may be able to use generic drivers from other sources.
If you have Windows 2000 try the "universal tweaked BT8x8/878 WDM drivers" from http://www.iulab.com . If you are running Windows 95/98 try the drivers from http://www.askey.com/html/2000.html. I use their "tv424.zip" driver with my CyberMail BT878 card and it works great with up to 720x480 capture on my P3 733Mhz.
<font size=-1>[ This Message was edited by: JHebert on 2001-10-25 15:46:08 ]</font> -
the miro studio pc-tv card is built by pinnacle systems so a driver is still available for it!! here is the link for U..http://www.pinnaclesys.de/uk/default.asp
Kev
Wow, that link has a lot better support than the Pinnacle USA site I looked at which was pinnaclesys.com instead of pinnaclesys.de . Thanks for the tip.
Slightly OT: Input from Miro Users Needed
By terryj in forum MacReplies: 0Last Post: 29th Mar 2010, 09:31 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 08:28 -
Miro - free, open source internet tv and video player
By louv68 in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2007, 09:31 -
MJPG miro DC30 best bitrate VHS to DVD
By dav75 in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2007, 06:36
