I have tried to use DVD2SVCD to convert my captured AVI to MPG2.
I use a miro dc10+ capture card and use MJPEG codec (must use for DC10).
If I load any downloaded AVI into DVD2SVCD I can encode them as I get a GREEN go button, but when I load my captured avi into the program, I cannot get a GREEN go button. I assumed that maybe DVD2SVCD was having problems with my MJPEG and loaded morgan codec onto my machine but still no go.
Different versions of DVD2SVCD makes no difference.
Any ideas?
Cheers
Take a look on the "AVI Hints" tab in dvd2svcd.
Cheers, Jim
My DVDLab Guides -
thanks for replying.
are you tell me this because the answer is in the avi hints and you would rather me read this than tell me the answer? I am posting because I have read alot and have not been able to work this out.
The avi hints deal with codec problems for DV avi. I am capturing via a miro dc10+ card in MJPEG. I do believe it is a codec problem but what exactly I am not sure. I do not know where SVCD gets its codecs from. As previously stated, I have loaded Morgan MJPEG codec onto my machine even thou I would of thought the pinnacle software would of loaded the codec it uses anyway. Still no go.
One again, thanks for taking the time to reply. -
I was thinking, if you got the Canopus DV codec, and converter, you should then be able to load your avi's into dvd2svcd and encode. That's all it says on the Hints tab...
Any time dvd2svcd has crapped out on me, either a) the Canopus thing has fixed it, or b)virtualdub has, by re-saving the avi using a different codec (divx mpeg-4 for example).Cheers, Jim
My DVDLab Guides
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
