Closed Thread
  1. i have a pocket pc 2003, and i hava a program to put a dvd onto a 128 multimedia card and it works ok.
    how can i convert divx,mpeg ect to fit on a multimedia card . what tools do i need and can i do batch encoding ? also what is the settings that i will need to use to do this please, been told that a 128 multimedia card can hold about 100 mins of movie, yes i know this is not very good quality but my dvd2pc program is quite watchable.thank you
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Craig Tucker
    You only need to post your question once, not 3 times.
  2. I don't quite understand this question, you seem to be asking how to do something that you have already done.
    Anyway if your pocket pc will play divx, then you can use virtualdub to convert your divx/mpeg files to a divx avi file. Use a bitrate calculator to determine the bitrate required to get the filesize you want for the movie. I would also suggest reducing the framerate to around 15fps for playing on a handheld device.
    If you want to ask more questions continue in your original thread
    https://www.videohelp.com/forum/viewtopic.php?t=212007&highlight=
