can someone please tell me how i get the audio to work in virtual dub,i get a good pic but no sound, i presume my leads are all connected correct as the pic and sound on win tv is ok.
thank you
Steve
Make sure you've selected your audio recording source from the windows volume control type thingy (you have to go to properties>advanced and select recording, then select your input). Then make sure you've turned on audio capture in VDub (Capture>Settings and check capture audio).
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 18:55 -
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum Capturing and VCRReplies: 3Last Post: 3rd Nov 2009, 09:35 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
