Right I have 2 xvid avi files that I want to join together, the 2nd file originally had an audio-sync problem on it so I ran a sync fix on it which corrected that but now when it comes to joining them in nandub I click on append avi segment to open the second avi and i get the following error
"cannot append segment: The video streams have different sampling rates (23.97500 vs. 23.97622)"
How can I join these 2 files together now without getting this issue, if anyone can help it would be great![]()
If both of these files are going to go on one dvd, why don't you just convert each one independently at 1/2 dvd and then author with something like tmpgenc dvd author, you will not notice the change in files.
Cheers guys, I have a xvid dvd player so I just like joining the 2 files together instead of reselecting the second file half way through!
So there is definatley no way to join these 2 files then as they are? -
Just change the framerate to 23.976 with virtualdub on direct stream copy for video and audio for both files and then join the saved files.
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 18:49 -
MEGUI MP4 to AVI XviD Error
By DruidCtba in forum Video ConversionReplies: 22Last Post: 6th Nov 2009, 14:35 -
joining xvid's
By DSLGuy in forum EditingReplies: 4Last Post: 13th Sep 2007, 12:29 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 06:12 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
