  1. I'm trying to play a Xvid which consist of two files.
    I doesn't matter which player I use and which part I play.
    When I play the Xvid the player tells me that there is an error and then just ends. I tried Media player, BSplayer Avi viewer.
    Gspot tells me that i have the xvid installed and also the audio codec. Someone knows this problem?
    trenchy
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    there is an error
    That doesn't tell me much - might it be that the AVI is corrupt?
    /Mats
  3. I'm a Super Moderator johns0's Avatar
    canada
    Install ffdshow instead of the xvid codecs,i get crashes with xvid codecs but not with ffdshow plus the graphics dont get warbled with certain xvid clips.
  4. Did you download the file ?, they always have problems.
    Can you open it in Virtualdub ?
    If it's wet, drink it
    My DVD Collection
  5. Yes I can play the movie in virtualdub and yes I downloaded the movie
    Any suggestion to solve the problem?
    trenchy
    Dec 2002
    My Swamp
    Have you scanned it for bad frames with virtualdub?
    It does sound like you have a corrupt file as Mats suggested .
    There are a lot of them out there. Especially on the likes of Kazaa.
