  1. How can I fix my video file i have that when played the audio part does not match the video i/e the character lips would start moving then a few seconds latter the audio would kick in is there a way to fix this? thanks in advance.
    canada
    Extract the audio and run it through besweet and set the delay for the amount of time it needs to match the video.
  3. What is your conversion method ?
    What are the details of your source file ?
    More information please !!
    If it's wet, drink it
    My DVD Collection
  4. I am using tmpeg to convert to mpeg 1 the source is avi i think that is what you want.
  5. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    I have noticed this problem also. It's not very noticable on short clips, but on full movies it's quite bad.
    Here's my solution:
    1) Capture with WinDV
    2) Frameserve with VirtualDub (BUT, go to Frame Rate Control/Frame Rate Selection and select Change video frame rate to match audio)
    This is a fractional change that will NOT affect encoding via your MPG encoder of choice.
    3) Encode to MPG
    4) Blah, blah, blah
    This fixes the problem pretty well. Note that I usually frameserve with VirtualDub anyway to trim the part out that I don't want.
    Hope that helps.
