I attempted to play the first VCD i have ever burned on my 2,500 Bose system yesterday and it wont play it. THen i tried playing it on my computer and it shows a screen that says i have to turn on 'PBC' in order to view the photos. How do i turn this on?? also does anyone know if Bose makes software i can install to be able to play VCDs? Thanks
i was just using windows media player. I downloaded both of the trials versions of those players and niether of them worked. please help!!
You must have one of those not so well know chinese dvd player. You should be able to turn on the PBC if you read the manual that came with it.
My player turns it on automatically. -
I have a Bose Lifestyle 28 DVD system. If anyone knows how to turn on the PBC for this player please help me. thanks.
Which Process did you used to create such VCD? I am far from being an ezpert but did you checked in the Players comments if you Bose Lifestyle is able to paly VCD's at all?
