Sorry if this question gets repetitive, but I can't find the exact solution/answer to my problem. I used DVD Shrink and DVD decryptor separately to rip my DVD that contains VOB files, because one of the episodes I had one their was troublesome. When I rip it though, and try to re-author it using Roxio's DVD Builder, the video and audio are out of sync, but when I burned it to a DVD there was no problem...can anyone help?
Also, the same dvd burned later start to pixelate? It's quite irritating. I'm not sure if this is because I used "automatic compression"? But if I were to use low-compression, it'll only allow me to burn 3 episodes worth, 75 min., so should would it be any better using Nero instead. Any input would be nice, thanks.
Results 1 to 1 of 1
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 08:10 -
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 04:14 -
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 05:32 -
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 17:41 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00
