Hi what is the best way to know which codecs i need and which I don't need?
I have alot installed but is there a set or a program that tells all?
Anyone?
Thks
when you run across a video you can't play -- then you need that codec .. otherwise don't install them before you need them ...
in the tools section are tools like g-spot which will tell you what codec you will need IF you have a file that doesnt play ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
