  1. I am converting a 576x432 23.976 fps 200 MB 20 min divx (I think it's a DVD rip). It's excellent quality. I'm trying to convert to mpeg2 and then burn to DVD-r and play on my DVD Player. I just want my encoder (TMPGEnc) to maintain the quality. I did a CQ 100 encode with a min bitrate of 2000 and a max bitrate of 9600. The average bitrate of the output came out to be about 6700. The mpeg2 doesn't look as good as the Divx. Why? I know Divx has better compression. My Divx had a bitrate of about 1500 and was a 200 MB .avi. My mpeg2 came out to be about 1 GB. My real question is why did TMPGEnc's CQ not give the required bitrate to make it look like the original. I even used Highest Quality Motion Search Precision. I could just jack up the bitrate to 9600 CBR, but that would not give me an automated solution. Also, with a VBR, I get better allocation of the bitrate; i.e. I can fit more on my DVD-r. There is quite a difference between 6700 and 9600. Any suggestions, explanations, tips, etc would be appreciated (especially in regards to TMPGEnc's CQ). Thanks.
    Mar 2002
    United States of America
    The reason why the MPEG-2 doesn't look as good as the DivX file is because each time you encode, you lose quality some-what. Most of the time, a copy will never look as good as an original...
  3. I figured out my own problem. CQ, even at Highest Motion Search Precision, cannot compete with 2-Pass VBR at Highest Motion Search Precision. The results were better at the same exact file size. I gave the minimum bitrate 0 (automatic). I think with TMPGEnc, this is what you have to do unless you can make the minimum and maximum and even amount away from the average. Since I'm using a high average (6700 kbit/s), and DVD Players top out at about 9600-9800 kbit/s for the video, and I really don't want a minimum of about 3700 kbit/s (way too high), a minimum of 0 is best. It produced near flawless results. In some ways, the image looks better than the DIVX file.
