hello,
I have used decrypter, dvdxcopy, smartripper, dvdshrink without success. I have finally be able to rip this disk to the harddrive using Clonedvd, but Clonedvd does not compress it to one dvd. Decrypter, smartripper, dvdxcopy, dvd shrink will not work. It stops at approximately 26 percent and gives me an error. I beleive there is a error on the original disk. Is there a program I can run to fix the rip that is on my harddrive so dvd2one dvd shrink will compress it???
thanks
make sure there are no smudges or anything on the original dvd as well.
if you're still having problems, try another dvd-rom drive if you have one.
Put 4 Sopranos episodes from 2 DVD5 to 1 DVD9
By audax in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2012, 01:23 -
Stargate SG-1 Season 6 & 7 A/V Sync Problems
By slider5634 in forum DVD RippingReplies: 16Last Post: 24th Jul 2009, 18:21 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33 -
Problems with removing "Piracy is theft" sequence from 24 season
By Hamilton in forum DVD RippingReplies: 2Last Post: 10th Jan 2008, 20:25 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
