topic![]()
I'm not sure how the legallity works on issues like this.. wether stream ripping is warez, the rules listed are not as specific to prohibit talking about it.
There is a program you will have to investigate on your own (ie. google) called Streambox ripper. To tell you the truth I have never gotten it to work, and the last version made may be too outdated to function. But hopefully this will put you on the right path.
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 15:55 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 11:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 06:06 -
converting RealVideo 10 to avi
By user543 in forum ffmpegX general discussionReplies: 2Last Post: 30th Oct 2007, 03:06 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05
