  1. Hi,
    I have a avi that is 720 x 576 with pixel aspect pal (1.067). 25 framerate
    It's made in premiere. DV PAL Conpressor
    When I convert it in tmpeg 1.2a or 2.0 the picture is not showing the whole frame ? the bottom on the frame where is subs are is missing.. the tmpeg is resizing the frame, why ?
    I want the 720 x 576 pal to keep aspect in 480x576 pal.
    I use the standard SVCD PAL template in tmpeg.
    This has worked for me before..
    Please help.. Urgent.. Gonna show this on a wedding on saturday..
    /Thx Stisse...
    try messing around with the settings under Settings->Advanced Source Aspect Ratio and Video arrange method. Then use the file->preview to view how it looks like.
  3. Thanks Baldrick !
    I solved the problem....
