When frameserving between VirtualDubMod and TMPG, I use to find some problems with some source films. The encoder just tell me that the file format is unsupported, and doesn't open the *.vdr file (created by VirtualDub)
I've encoded a lot of films lately, and none gave me that error, before and after trying to encode that one. It works fine in WMP, DivX or other Media players. Also TMPG and VirtualDub opens it directly.
Does any one know what happens here? Any clue?![]()
Results 1 to 12 of 12
How do I turn off the proxy? I don't know what are you talking about!
The Multimedia file reader is at the top priority, but still not supported! -
In the Virtual Dub folder you created when you unzipped the original downloaded file there is a folder "aviproxy". Inside that folder is a ReadMe file and Proxyon and Proxyoff files
No, I'm from Iowa. I only work in outer space. -
I've tried all of the frameserving troubleshooting methods, proxyon, mscvrt??.dll, etc. TMPGEnc will open up the .vdr file because I have already installed the handler and the vfapi plugin, but when I try to set any filters or just plain encode, it always gives me a "Divided by 0" or "The error occured when ACM was initialized" error. I know my source is fine; why does this happen? I am using the latest VirtualDub (1.5 something). Is there any fix for this?
Try saving the audio as a wav file as I suggested. Virtual Dub can do that. Then use the wav file for the audio in TMPG.
Spoke too soon. I had TMPGEnc do a 2-Pass VBR. It went 50% of the way and then said "Illegal floating decimal point calculation order." I had VirtualDub scan it for errors and found none.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 07:01
