Hi,
What's the best codec for 64kbps songs for a small mp3 player? I either have the option of converting the songs to wma 9 format at cbr (using) or to mp3 64 kbps using lame and either abr or cbr. What's the best settings? Thanks. (i use dbPowerAMP for conversion).
Also, is there a way to batch process the conversion of mp3-->wma9? microsoft's website talks about some sdk kit but i don't know any programming. thanks.
WMA would be better at low bitrates, it uses a better psychoacoustic model than the now-dated MP3. If you must use MP3, the ABR (Average Bit Rate) would be better, as it allows the codec to vary the bitrate according to the complexity of the music.
I think CDex might be able to batch encode for you, but I'm not sure.
Basically, I would find a program that supports both and try all formats out, and see which you like best.
Cobra
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
In Dash DVD Player for music Mp3's
By wenospeak in forum Off topicReplies: 0Last Post: 4th Sep 2009, 22:42 -
ripping cd to m4a at 64kbps and get tag information
By hamilton accie in forum AudioReplies: 1Last Post: 28th Mar 2009, 09:04 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 10:49
