I just upgraded from dial-up to roadrunner. First let me say holy-shit that's fast. Now on to my question. I was using a free firewall called Sygate Personal Firewall when I was on dial up. Now, I don't know if I need anything stronger or not since I am on a much faster connection. My modem is hooked up to a router so I don't know if the router helps or not? What do you think.
Results 1 to 10 of 10
Originally Posted by pyrate83
Your router should have a hardware firewall built in unless it's really ancient. -
Routers have great hardware firewalls. You can set up rules and do very advanced things with them. IMO, a hardware firewall makes a software one redundant... Paranoia
Yes you're both right my router does have a built-in 128 bit encryption on it plus it sounds like my sygate personal firewall is still good to use.
Thanks for the info! -
A router just by itself provides adaquate protection from most attacks. I still suggest people runn a software firewall on their computer, but since its only secondary, you could get by with any program you like best.
Case in point, My software firewall has not been triggered once since I installed my router a few years ago.
And no, that is not an invintation for hackers to try."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Originally Posted by Solarjetman
If you're behind a properly configured hardware firewall/router, you are pretty safe from the outside world.
Keeping a software firewall installed and running is good for YOU having the control over what programs can and cannot "phone home" without your knowledge.
A Linksys WRT54G and Kerio v2.1.5 for me baby -
Thanks for all of the help guys. Funny thing though, now that I am behind the Windows XP firewall, Sygate's Personal Firewall, and my router's firewall, I have had zero logs of anyone trying to scan my computer which I seemed to get when I was on dial up. I feel pretty safe now.
Sygate is a wonderful software firewall ... No offense but Zone Alarm is junk compared to Sygate.
Anthony
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
How many firewalls should we used ?
By SingSing in forum Newbie / General discussionsReplies: 12Last Post: 3rd Jul 2009, 10:50 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
