I saw one advertised on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2790643564&category=3759
It looks quite cheap for what it implies it does (ie: convert analog video/audio to avi format output (what exactly that means I don' t know) at 720x480 resolution and 30 fps).
Has anyone ever heard of such a device? Has anyone tried such a device?
Thanks,
Icarus
It will capture composite analoge source via usb to avi format fileand/or software encode to ??
Functioally same as other cap devices using software encoding.
Software encoding is very dependant on your system setup, requires much more computing power/resourses than a hardware encoding device.
Many pro's/cons for software/hardware
Hardware ecoders cost more but work well without a highend system, my choice for now. The more powerfull your sys, the less need for hardware encoding.
Hardware encoders can be very propietory as to capture software, once captured though. files are compatible with most all editing software.
Sabrent Video DVD Maker Video Capture Creator Anyone?
By Rayj00 in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2011, 11:10 -
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum Capturing and VCRReplies: 4Last Post: 21st Nov 2010, 23:22 -
Burning DVD's with Roxio Creator Basic 9 or Windows DVD maker
By bhess55 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 03:55 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
