ok here goes can anyone tell me the easyest way to burn xvid,divx files onto cd /dvd what tools required etc im very new to this so go easy sorry for being a pain 1 day i will be as good as u guys
Results 1 to 15 of 15
What guide did you look at that is causing you a problem? I would guess the easiest would be to use TMPGENC to convert the avi to dvd quality and then use TMPGENC DVD Author to author it and burn it.
hi all downloaded dvd author/winrar is this the right one it says 14 days to buy licence
No, these are the ones you want...They have a 30 day trial
TMPGEnc (encoder) http://www.pegasys-inc.com/en/download/tp.html
TMPGEnc DVD Author, http://www.pegasys-inc.com/en/download/tda.htmlNo, I'm from Iowa. I only work in outer space. -
downloaded the author every time i click on the icon it goes back to installcan any one help
.........what do you want, a one-to-one ******* tutorial?
How about I come round to your house and show you?
TMPGEnc to produce your avi file and TMPGEnc Author to output the disk.
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Try double clicking the .exe rather than using your mic and asking it it to start.
Will Hay, bummertgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by richdvdtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Originally Posted by Will Hay
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
