I have used Goldwave and VirtualDub to split the audio/video then TMPGEnc to make the system files. Put these into TMP DVD Author, video is fine but no audio. Never had this before, so I'm stuck. I've played the individual files, these seem fine.
Cheers
Mark
You posted your question a few days ago so I'm not sure if you've figured it out yet or not, however. It seems that the problem is you're not including the *.wav file when you're authoring the DVD. TMPGEnc will spit out an *m2p as well as *.wav file, one is the sound and the other is the video, after you have loaded the *.m2p file in 'TMPGEnc DVD Author' there is an option to replace the sound. choose this option and select the *.wav file then author the DVD and it should play fine, assuming your stand-alone DVD player is prog'd correctly for PCM audio. Hope this helps, have fun.
|cemann
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
Normalize Audio with TMPGEnc DVD Author 3?
By jonas more in forum AudioReplies: 2Last Post: 16th Oct 2008, 21:10 -
Audio Issues in DVD Shrink Re-Author
By mpalm887 in forum DVD RippingReplies: 5Last Post: 21st Jan 2008, 15:28 -
Background audio with still image on TMPGEnc DVD Author?
By tikigod19 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2007, 13:44
