Im a non-noob first of all. Is it possible to convert and AVI file to DVD (MPEG 2) ? The reason I posted is that I didn't see any info on the left-hand side in the convert section. Thanks
Guides for that are here:
https://www.videohelp.com/guides.php?howtoselect=4;10#4;10
Personally I use dvd2svcd(with cinemacraft encoder):
http://www.doom9.org/index.html?/mpg/dvd2svcd-avi.htm
Er, being a non-noob you should know that an SVCD is mpeg2 and the only difference between that and dvd mpeg2 is the resolutions (Ntsc 480x480 for svcd and Ntsc 720x480 for dvd) and bitrate and surely you have done an avi->SVCD conversion before?
Once you learn to use dvd2svcd go get the D2sRoba plugin for it and learn to use that (best forums for it are at doom9).
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
