Ok, I tried this a while ago, and it didn't work for me. I was reading one of the guides to the right on ripping, and it said that a dos window should pop up when you load your list file...that doesn't happen. Does anyone know what I've done wrong? The read-me file doesn't help much. Is there a trick to installation, or an extra that you need? TIA...
Liz
There isn't a trick. You need vob2audio.exe, streams.exe and a .lst file created by smartripper or selfwritten.
Yep, I have all that, I'm still not getting the program to work. It will load my list file, and that's it.
Liz -
<font size=-1>[ This Message was edited by: Truman on 2001-10-26 07:04:43 ]</font> -
Did you copy lmpgspl.ax to c:\windows\system (c:\winnt\system32)?
Ok, I did that...still have no dos window popping up, and nothing showing up in audio streams. I've tried ripping both ways...enabling streams and not. Very frustrating.
Liz -
yea...im the author of the guide that u are trying...i dont get whats happening, it should work a MS-dos windows should pop up ....i suggest to uninstall the program and download it again at Doom9.net if it is still happens i dont kno what to do..oh yea thanks for using mah guide
not having any luck creating my tutorials
By Dire in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2012, 23:12 -
Anybody have any luck hacking TV/DVD combos?
By Martineaux in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Mar 2012, 12:54 -
anybody had any luck with playing divx softsubs in Wmp 11 ?
By davexnet in forum Software PlayingReplies: 1Last Post: 12th May 2011, 02:02 -
Zero luck with creating Region Free discs
By THRobinson in forum DVD RippingReplies: 16Last Post: 3rd Feb 2011, 16:43 -
Tried every flv to mpg convertor program, no luck.
By ry94080 in forum Video ConversionReplies: 4Last Post: 16th Jun 2007, 01:01
I am at a loss....
