Hi everyone,
I am not sure if I'm doing anything wrong. But I thought earlier versions of DVDShrink had an option to always run Deep Analysis when processing? Seems like the latest version (3.1.7 official release) no longer does that (I can't find the option in Prefences), and I have to manually hit the Deep Analysis button before doing a full disc backup. Is there any way to auto-force a Deep Analysis every time? I have come across some titles that had to be shrunk down to less than 65%, and I worry the quality would be compromised.
Any help would be greatly appreciated. Thanks in advance!
Spiffy
when you get to the point of doing the backup, there is a tab that has a check mark option to do a deep analysis. It turns off when the compression is 100% (no need to do a deep analysis).
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 15:37 -
Deep Fringe Antenna
By fusionteck in forum DVB / IPTVReplies: 4Last Post: 4th Oct 2009, 17:14 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 17:43
