Browsing through the forums, i always stumble on some advice that states: 'dont burn your dvd to the rim, leave some empty space at the end of the disc'.
For that i conquer, i currently use riteks g03 and i make sure that i dont burn over 4 gigs on the disc; otherwise, based on many previous experiences, i will face some playback problems at the end.
So here is the question: is there any media out there that you can burn to the rim everytime (video & data alike) without having any errors (playback or pixelation)?
I burn Maxell 4x DVD-R disks (the made in Japan ones) all the time.
I am transferring tapes to them, so I want the most space possible. Because of this, I burn at the 4 hour format, the 'LP' on the Panny E50.
I've fit (using flexible record) 4h10min on a single disk several times. I haven't bothered to see if this is 'right to the edge' or not, but it's got to be close.
I've never had problems with these disks, even though the E50 is technically a 1x machine, and these are 4x disks.
Hope this helps!Mechworker
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 13:12 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
CDROM that burns commercial media
By Krispy Kritter in forum MediaReplies: 6Last Post: 19th Dec 2007, 10:30 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 14:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23
