I am having problems creating the dvd folders, or burning a dvd. Here is the log error:
******** Multipexing elementry streams
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [???] File C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpv unrecogniseable!
**ERROR: [???] Unable to read from C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpa.
System.IO.IOException: The process cannot access the file "C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpv" because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.File.Delete(String path)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
This is when using both types of mplex. I would appreciate any help.
Actually that wasn't the correct message. Here is the correct message.
System.IO.FileNotFoundException: Could not find file "C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpg".
File name: "C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpg"
at System.IO.FileInfo.get_Length()
thanks again for any help -
Can you post the whole log?
Certainly, I should have done this before, I'm sorry.
Starting SVCD2DVD: v1.51.2.0
Begin time: 10:03:17 AM
Analysing File: C:\Documents and Settings\Josh\Desktop\2ndhandLIONS.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: mpeg stream contained no scan information (user) data
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
-->Processing 1 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 720
Standard: NTSC
Audio SampleRate: 48000
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file C:\Documents and Settings\Josh\Desktop\2ndhandLIONS_DVD.mpv...
File C:\Documents and Settings\Josh\Desktop\2ndhandLIONS.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 1
System headers = 1
Video stream 0 packets = 1, total bytes = 1978
Saving stream 0xC0 into file C:\Documents and Settings\Josh\Desktop\2ndhandLIONS-0.mp2...
Summary:
MPEG Packs = 1
System headers = 1
(Total size: 3991MB, Duration: 00:26:59, Rate(MB/Min): 147.84)
******** Resampling audio from 44.1 KHz to 48 KHz
Skipping....
******** Trimming start of video ES
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5() -
Can you do the following & post the output:
Start Menu-> Run:
(copy & paste the following)
cmd /K mpgtx -i "C:\Documents and Settings\Josh\Desktop\2ndhandLIONS.mpg" & pause & exit
(assuming thats where the file still lives)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I've downloaded a couple of tv rips that had extremely low bitrates in the first few secs of the video due to the fact the encoder have'nt had time to "warm up". On my files it was visible. Anyway, after cutting off this part I had no problem authoring with svcd2vd.Originally Posted by kuyote
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 17:28 -
SVCD2DVD Audio problems
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 6th Mar 2008, 11:53 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 10:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 04:31
