Hello all,
I am working with WinOnCD3.8PE extended VCD editor. When I try to save my work (the layout in the VCD extended editor) the file does not always save correctly.
Please you run Systeminfo.bat first.My OS is WIN 98.
Systeminfo.batfrom Roxio)
dir %windir%\System\Iosubsys > c:\c2temp.txt
dir %windir%\system32\drivers > c:\c2temp1.txt
attrib -H c:\autoexec.bat
attrib -H c:\config.sys
copy /A C:\autoexec.bat /A +c:\config.sys /A +C:\c2temp.txt +C:\c2temp1.txt /A c:\c2sup.log
del c:\c2temp.txt
del c:\c2temp1.txt
attrib +H c:\autoexec.bat
attrib +H c:\config.sys
notepad c:\c2sup.log
My c2sup.log:
SET BLASTER=A220 I7 D1 H7 P330 T6
SET SBPCI=C:\PROGRA~1\CREATIVE\AUDIO\DOSDRV
Rem TShoot:
set temp=c:\temp
SET PATH=D:\AEDTOOLS;%PATH%;D:\PROGRA~1\ULTRAEDT
rem
rem *** DO NOT EDIT THIS FILE! ***
rem
rem This file was created by the System Configuration Utility as
rem a placeholder for your CONFIG.SYS. Your actual CONFIG.SYS
rem file has been saved under the name CONFIG.TSH.
rem
Volume in drive C is SYSTEM
Volume Serial Number is 2B7C-14FC
Directory of C:\WINDOWS\SYSTEM\IOSUBSYS
. <DIR> 05-25-01 14:08 .
.. <DIR> 05-25-01 14:08 ..
BIGMEM DRV 9,952 05-05-99 22:22 BIGMEM.DRV
ESDI_506 PDR 24,406 05-05-99 22:22 ESDI_506.PDR
HSFLOP PDR 25,741 05-05-99 22:22 HSFLOP.PDR
RMM PDR 13,242 05-05-99 22:22 RMM.PDR
SCSIPORT PDR 23,650 05-05-99 22:22 SCSIPORT.PDR
CDR4VSD VXD 197,884 03-27-01 11:50 CDR4VSD.VXD
ATAPCHNG VXD 11,311 05-05-99 22:22 ATAPCHNG.VXD
CDFS VXD 59,133 05-05-99 22:22 CDFS.VXD
CDTSD VXD 13,884 05-05-99 22:22 CDTSD.VXD
CDVSD VXD 32,419 05-05-99 22:22 CDVSD.VXD
DISKTSD VXD 18,809 05-05-99 22:22 DISKTSD.VXD
DISKVSD VXD 10,194 05-05-99 22:22 DISKVSD.VXD
NECATAPI VXD 9,926 05-05-99 22:22 NECATAPI.VXD
SCSI1HLP VXD 19,270 05-05-99 22:22 SCSI1HLP.VXD
TORISAN3 VXD 11,067 05-05-99 22:22 TORISAN3.VXD
VOLTRACK VXD 18,491 05-05-99 22:22 VOLTRACK.VXD
INTELATA CAT 5,795 03-17-00 0:00 IntelATA.CAT
INTELVSD VXD 25,809 03-09-00 0:00 IntelVSD.VxD
INTELATA MPD 85,504 03-09-00 0:00 IntelATA.mpd
APIX VXD 22,603 09-10-99 19:06 APIX.VXD
CDRALVSD VXD 20,047 03-27-01 11:00 CDRALVSD.VXD
C2SCSI MPD 31,232 03-27-00 17:08 C2SCSI.MPD
ENSQIO VXD 23,727 03-01-99 18:55 ENSQIO.VXD
PRTSEQRD VXD 11,309 01-11-01 2:00 PrtSeqRd.vxd
ACBHLPR VXD 40,508 06-11-01 11:23 acbhlpr.vxd
IOMEGA VXD 25,247 04-18-00 7:11 iomega.vxd
CDUDFRW VXD 155,387 01-11-01 5:00 Cdudfrw.vxd
UDFREADR VXD 100,888 01-11-01 5:00 UdfReadr.vxd
CDUDF VXD 133,897 01-11-01 5:00 Cdudf.vxd
CDRPWD VXD 56,323 01-11-01 5:00 Cdrpwd.vxd
30 file(s) 1,237,655 bytes
2 dir(s) 3,429.05 MB free
Directory of C:\WINDOWS\SYSTEM32\DRIVERS
. <DIR> 05-25-01 14:05 .
.. <DIR> 05-25-01 14:05 ..
WDMFS SYS 4,064 05-05-99 22:22 WDMFS.SYS
WMIDRV SYS 14,800 05-05-99 22:22 WMIDRV.SYS
CCPORT SYS 31,680 05-05-99 22:22 CCPORT.SYS
WMILIB SYS 3,600 05-05-99 22:22 WMILIB.SYS
KMIXER SYS 137,120 05-05-99 22:22 KMIXER.SYS
PORTCLS SYS 165,424 05-05-99 22:22 PORTCLS.SYS
REDBOOK SYS 5,664 05-05-99 22:22 REDBOOK.SYS
SBEMUL SYS 36,112 05-05-99 22:22 SBEMUL.SYS
SWMIDI SYS 52,656 05-05-99 22:22 SWMIDI.SYS
SYSAUDIO SYS 45,456 05-05-99 22:22 SYSAUDIO.SYS
USBAUDIO SYS 40,272 05-05-99 22:22 USBAUDIO.SYS
WDMAUD SYS 68,096 05-05-99 22:22 WDMAUD.SYS
HIDPARSE SYS 44,368 05-05-99 22:22 HIDPARSE.SYS
UPDATE SYS 60,592 05-05-99 22:22 UPDATE.SYS
HIDVKD SYS 5,088 05-05-99 22:22 HIDVKD.SYS
USBD SYS 18,912 05-05-99 22:22 USBD.SYS
HIDCLASS SYS 23,520 05-05-99 22:22 HIDCLASS.SYS
USBHUB SYS 35,680 05-05-99 22:22 USBHUB.SYS
UHCD SYS 30,448 05-05-99 22:22 UHCD.SYS
GM DLS 3,440,660 01-08-99 18:10 GM.DLS
GMREADME TXT 576 01-08-99 18:10 GMREADME.TXT
GAMEENUM SYS 10,512 09-09-99 7:00 GAMEENUM.SYS
HIDGAME SYS 8,880 12-08-99 7:00 HIDGAME.SYS
APMBATT SYS 4,384 08-11-99 10:46 APMBATT.SYS
KS SYS 117,056 11-07-00 15:16 KS.SYS
STREAM SYS 41,920 11-07-00 15:16 STREAM.SYS
MSKSSRV SYS 6,368 11-07-00 15:16 mskssrv.sys
MSPCLOCK SYS 4,800 11-07-00 15:16 mspclock.sys
MSTEE SYS 4,896 11-07-00 15:16 mstee.sys
SWENUM SYS 3,456 11-07-00 15:16 SWENUM.SYS
30 file(s) 4,467,060 bytes
2 dir(s) 3,429.04 MB free
Hi,
I have the same problem and am looking for a solution as well.
I am not sure why you posted your system info stuff here though. What makes you think it is not a software bug ?
testcase -
I figured out how to work around this problem...
Assuming you have a number of nodes connected in a chain, all under a starting node on a higher tier (such as the chain of nodes that gets created when you use the wizard) you need to exit out to the highest tier of the chain, highlight the starting node, and THEN save your project. This will ensure that EVERYTHING gets saved.
Regards,
Corporate Dog
SOS! I have output file from convert by mencoder but i don't know conmand
By zerround in forum Video ConversionReplies: 0Last Post: 24th Feb 2012, 01:38 -
SOS Win7 Update hangfire- #8 never completes
By ahhaa in forum ComputerReplies: 3Last Post: 17th Feb 2012, 00:48 -
SOS- Registry Help Needed: Stop Repeating Windows Installer (XP)
By ahhaa in forum ComputerReplies: 6Last Post: 20th Nov 2011, 06:41 -
SOS: how to capture flv,
By dainova in forum Video Streaming DownloadingReplies: 6Last Post: 19th Oct 2011, 11:26 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55
