Hi, i have two avi files, which i want to join. The avi files are of different data rate so i dont use Virtual Dub to join them, instead i have used DVtool, to join the .avi files. When i get the completed .avi, TMPGenc for some reason doesn't recognise it as one large file, i mean, the joined file is 1.5Gb and is 180mins in length, but when i load that file into tmpgenc it recognises it as only half of the file, e.g it would only encode cd1 instead of the entire film??
I know it may sound confusing!!
Any help would be greatly appreciated
thanks
p.s. this happens not only with .avi, but with mpg files too
You don't have a proper join. You will have to encode the files seperately.
Blackmagic Intensity Pro - NTSC Captured File Not Recognised at Interlaced?
By kauri in forum Capturing and VCRReplies: 22Last Post: 22nd Nov 2011, 13:21 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 14:27 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 04:41 -
ASFBIN and Movica : Batch File Joining Possible ?
By Alterego in forum EditingReplies: 0Last Post: 12th Oct 2007, 04:18 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05
