  1. Can anyone tell me if there is a way to burn the bonus features of a DVD. Also, I just burnt The Godfather using DVD decrypter and DVD to AVI and Tmpge and it took like 12 gigs of space to do it. How much space does DVDx take and and are the times comparable? Basically, is using DVDx the superior way to go?
    Thank you to anybody who can help me.
    May 2001
    Ramstein, Germany
    1. for the cutscenes you have to find the group of vobs with them in it and encode those.
    2. DVDx is perfect for little hard drives but from what I have seen has pretty bad quality problems. If you have the space you should still use tmpge if you use that.
