When I use FlaskMpeg to open the IFO file (using "Open DVD", I selected the video stream, audio stream, and the subtitle, and then "flask this DVD". But the finished avi file does not have any subtitle at all. What have I missed? Thank you for your help. BTW, the DVD is "Mission Impossible II".
Did you use the "subtitled fixed" version of FlaskMPEG? The older/original version doesn't handle all subtitles properly.
Secondly, did you rip your movie with SmartRipper? If you did, you must rip in "File Mode", not the default "Movie Mode" for FlaskMPEG.
Regards.
Michael Tam
w: Morsels of Evidence -
What's the "subtitled fixed" version?
Is it the latest one (0.6 preview if I'm correct) or another one?
FlaskMPEG has had some problems with subtitles from some DVD titles. There was a guy compiling a "subtitle fixed" version of FlaskMPEG.
He recently released a "subtitled fixed" version of FlaskMPEG 0.6 prev1.1. You can get it from doom9's site.
Regards.
Michael Tam
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
