Hi. What is the best and fastest method or program to burn dvd-r's from movies/files on your hard drive and how long does it usually take for u?? Thanks alot!!!!
for the prgrams to use i suggest you check the guides to the left..
it all depends on what you have and what you want.
time also depends on what you have and what you want.
if you have an ISO on your HD then it shouldnt take more than 10-20 minutes to burn (depending on burn speed as well of course)
you could use DVD Decrypter or Nero
If you have VOB BUP and IFO files then it shouldnt be much different in time but you could use other programs
however if the files are too big to fit on a 4.7Gb disc you will need to re-author somehow (can be done simply with DVD Shrink)
more info needed
and more background work also needed.....
Zworg2
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Can ImgBurn Make an Image of a Hard Drive on a Computer?
By drstew in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2008, 08:00 -
how do I make video available for downloading onto the users hard drive?
By frankri in forum MacReplies: 2Last Post: 9th Apr 2008, 16:42 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
