I have some video files in the following format:
Width 352 pixels
Height 240 pixels
AUDIO
Bitrate 56kbps
Audio format MPEG Layer-3
VIDEO
Frame rate 14 frames/second
Data rate 79kbps
Video sampler rate 24 bit
Video compression MS-MPEG4-V3
I have two questions which method of making a vcd would produce the best quality.(read that it was ATI2VCD and Nero)although I a novice so i don't really know.
Finally is it possible to convert/burn these file to dvd-r and which method would produce the best quality.
Thanks alot in advance
Well, I suppose you have an AVI file (MPEG4 codec). The best quality MPEG video is produced by Cinema Craft Encoder, but TMpgEnc's nearly as good and about $2000 cheaper.
Your MP3 sound should be converted to Wave first (for example with dBPowerAmp Music Converter / DMC) and then to MP2 using tooLame.
It doesn't matter if you use Nero or EasyCDCreator or whatever, but: the slower you burn, the better the quality will be.
To burn a DVD you have to use an authoring tool. The best I know is DVDMaestro, but it only runs under NT/2000/XP and there is no demo or trial version available.
The REAL problem will be the framerate, because no (S)VCD/DVD will work with 14 fps. You can try using VirtualDub for this, but I guess your video will be too fast (or slow) in the end.There are only 10 types of people in the world:
Those who understand binary
and those who don't.
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 20:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
