When ever I burn a DVD it seems to be a bit blurred and jerky. I burn at the max speed. if I burnt them at a slower speed would it cure the problem? And if not have you any suggestions? I use Cucsoft to change them to mpeg and TMPEng DVD author to write and they are usually AVI files.![]()
Am not familiar with cucsoft so can not really comment on its encoding abilities, one thing to be aware of is the framerate of the AVI and your encoded mpeg, if these do not match you may encounter stuttering playback.
Can you give more details of your conversion method e.g your source file and other settings.Originally Posted by callen
I convert from avi to DVD. It does it all for you when you select this option the other options are avi to mpeg and mpeg to mpeg2 and then there is avi to vcd and avi to svcd. It gives the options also of PAL or NTSC. I chose this program because it was easy to use. But surley it not all avi files should be blurry and jerky so it must be something I am doing.
Dont know if it will help but this is the log from a conversion:
Cucusoft AVI to DVD VCD SVCD MPEG Converter Pro - v4.11 (Full Version)
OS Info = Windows XP Home Edition Service Pack 1, build = 2600
CPU Info = x86 Family 6 Model 8 Stepping 1, AuthenticAMD, AMD Athlon(tm) XP 2600+
DirectX Info = DirectX 9.0a
Video Filter Graph:
Audio Filter Graph:
MPEG Layer-3 Decoder
File Name: C:\Program Files\mIRC\download\[tmd]the.butterfly.effect.(ftf).ts.(1of2).avi
File 4CC: MP43/MP43
File size: 118890496
Video:
Resolution: 352 x 240
Frame Rate: 14.99
Total Frames: 40604
Total Time: 00:45:9.64
Selected Frames: 40604
Audio:
Channels: Stereo
Sample Rate: 24.00 kHz (will be converted to 48.0 kHz)
Bits per Sample: 16
Total samples: 65031366
Maybe you understand it better than me
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
DVD Recording speed
By jcsmith in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jul 2008, 06:01 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
Anything like CD-DVD Speed for the Mac yet?
By NimChimpsky in forum MacReplies: 3Last Post: 26th Nov 2007, 18:08 -
dvd burning speed
By nobbyiscool in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2007, 07:54
