I am trying to back up Finding Nemo (Movie Only but menus intact to allow for scene selection)- and Yeah, I've read all the earlier posts. I don't see anything on this however
My problem is that any DVD & DVDDecrypter (most recent versions of both) both announce that they cannot accurately determine the encryption keys (No weak blocks - DVD Decrypter announces).
I can press ahead and rip the Vob's or just use my prefered idiot proof solution and use CloneDVD. Hoewever the resulting disc will only play the opening intro and menu. Every option you select (including Play Movie) makes the disc spin for a few seconds and then the menu re-appears.
I may well be doing something stupid (damn you, noobie moron!) but this never happened with any of the LOTR backups I made. In each case I have burned main movie, english 5.1 soundtrack (Dolby & DTS) and used the "Preserve Menus" checkbox within CloneDVD and everything works perfectly.
In Nemo the scene selections menu displays but selecting any scene just reloads the main menu.
Any advice? Can I ignore these warnings? SHould I use some other bit of software to re-author? (I've got the Nero 6 with Recode - some are giving it rave reviews but I haven't had time to try it yet)
Hey, call me an idiot and b*tch-slap me if you must but someone please reply.......
Baldrick45
Not sure if I read you right - you can't rip Finding Nemo with AnyDVD? I did that with AnyDVD, months ago, no sweat. Run the driver, windows explorer, select all from VIDEO_TS, copy to HDD folder. No problem.
In fact, if it wasn't for the fox head in my toolbar, I wouldn't know ANyDVD was there. It's a driver, not a ripper...
But I don't think this is the issue, because if you couldn't get past the encryption, how would you be even able to play the menus?
If this is a reauthoring issue, I recommend DVDRemake these days, maybe DVDStripper if you have no dough. -
Did you try DVD shrink? It worked for me with version 3B5.Originally Posted by baldrick45Sam Ontario
If i recall,this dvd has 2 long tiles,the longest being the directors added comments,and the second title,which is a little shorter,is the movie itself.
Make sure you select the right title.This may be why there is no movie to play.bmiller,ont.canada -
Rip it with decrypter in file mode.
If you tried that and it didn't work, what are your settings? I just ripped and backed up Nemo last night. DVD Decrypter 3.1.4.0 -
try this for movie only w_original menus...
https://www.videohelp.com/forum/viewtopic.php?t=185976&highlight= good luck. -
DVDdecrypter worked for me, only last week.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 08:17 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 01:25
