New version of Alparysoft Lossless Codec is released.
http://www.alparysoft.com/prod/compression/index.php
Codec is developed for encoding and decoding of video without
any mathematical losses (i.e. source and destination video are absolutely identical after encoding/decoding process)
seems cool and better than HuffYUV!![]()
if you didnt have to use thier software to make i work i seem to recall
Originally Posted by Luna*
I tiried it out and it seems to work A OK with Virtualdub. Qualitywise, donīt see any difference with hffyuv, files tend to be 1/5 smaller though... 8)
"This is true in all walks of life: Man takes care of the quantity, woman the quality." -
Just did a test on it (using VirtualDub) and got some odd results:
Code:Source : 7000 frames - 368x272 30fps Codec Setting Speed File Size ----- ------- ---------- --------- Huffy n/a 64 fps 776 mb Alpary RealTime 32 fps 666 mb " MaxCompress 11 fps 679 mb
It seems too slow for serious full-size capture, file sizes are not much better, and why the larger file-size using the Max Compression option.
I'll stick with the tried-and-true Huffy. -
Originally Posted by bunyip
the results were twice the size of it on pc with Athlon XP 1700+,256 RAM. -
tell me your system configuration u had made that tests on? and codec settings?
The codec: RGB format enabled, prediction enabled.
I also have a Pentium4 3ghz with 1gb mem, that is used for video processing but I haven't tried the codec on this, obviously it should be faster.
Are you saying that you got large file sizes using the Athlon?
Re-compressing many times with lossless codec in Vdub introduces colorbleed
By Mephesto in forum Newbie / General discussionsReplies: 21Last Post: 19th Feb 2012, 06:39 -
Lossless codec did THIS to a video i made...help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2011, 06:49 -
Use Techsmith codec (RGB Lossless) on Potplayer
By stranno in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2011, 09:59 -
lossless codec for QT pro, vegas platinum
By benrtc in forum Video ConversionReplies: 1Last Post: 6th Apr 2008, 02:43 -
Lossless Audio Codec Comparison '07
By Tab in forum AudioReplies: 8Last Post: 3rd Jul 2007, 01:08
