(NEWBIE) OK this is what I am doing 1). use DVD Decypter to capure Vid 2). use DVDX to convert to VCD 3) . use VCD Easy to make BIN/CUE Image 4).Try to use nero to burn
The problem is NERO says File is to big not sure how to make smaller or what I am doing wrong. When useing DVDX I first selected 80 min , Nero says to big so then I selected 74 min Nero says that thats to big also. Please Help Thanks
" May The Force Be With You"
The file size for the 74 min cd is 729 mb. How would I tell DVDX to make smaller MPEG size and still fit the movie on 2 CD's?????? I have tried eazy vcd noluck making the movie I will get what ever software ya'll thing would make a VCD. I have allready made about 15 coasters so I think I am doing something wrong. The reason I switched to DVD Decrypter-DVDX-VCD Easy-NERO was because Tjshadyluvr@aol.com told me it works for him/her all the time(got email from this cite and emailed directly)
" May The Force Be With You" -
I meant the original mpeg before trying to author it. The one that is sitting on your hard drive. As long as it's under 800mb it will fit fine in Nero, assuming you are using 80minute/700mb CD's. You juse have to select The VCD compilation in Nero.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
Burning Failing in Nero 7
By Osaka in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2007, 14:03
